- Aug 11, 2015
- Thread Starter
- #21
After continuously reading nothing but Crosshair VI Hero threads because there has been nothing written about Prime X370 Pro ..... I would have to state there is VERY little similarity in the BIOS' between the two motherboards. Think of the X370 Pro as 1/4 of the motherboard as the Hero. There is not much you can affect or change in overclocking or memory configuration with the X370 Pro. While there seems to be constant updates and monitoring of the Hero and on the forums, there has been nada regarding the X370 Pro. It is the red-headed stepchild of ASUS. Haven't got the memory to post consistently past 2133. If I somehow effect a change to 2400 and get into Windows, as soon as I turn off the system or reboot, I am back to 2133. Have been able to get all cores to 3.77 or 3.825 Ghz for a session, but again if turned off or rebooted, the system will come up at 3.4 Ghz stock core clock and 2133 Mhz memory speeds. Only one BIOS revision past 0502 has been released. That is 0504 which I am on and getting the reset to stock clocks all the time. The only solution is once I get it overclocked past stock .... DON'T turn off the system. I just hope that once the CH6 gets fully ironed out, that ASUS will lavish attention on its red-headed stepchild, the Prime X370 Pro.
