are thermal pads sticky on both sides?
Illah
San Francisco
I know, I should use AS epoxy or some ****, but I don't have the money and I don't want a permanent attatchment.
So, are these sticky on both sides?
I can't find thermal tape ANYWHERE for some reason. If you know where I can get any let me know.
--Illah
Oh, it's not for my CPU! I have some AS3 on the way for that. It's for my vid card memory heatsinks. I'm not ready to commit to a permanent epoxy bond... I have these extra heatsinks so I figured I'd toss em on my card with some thermal tape or something.
--Illah
Use Krazy Glue and AS
when you want to remove the sinks, put the Card in a anti-staic bag, Seal it...
Put it in the freezer for 30min, and the Krazy glue will come off Very easy with a Razor or Credit Card
AS in the Center, Krazy Glue on the corners
That's sounds good, jay. I think I'll do that. Plus, I can use crazy glue on things besides the computer (helps me justify to my girlfriend why I'm spending more money on the machine).
My spoon is too big!
--Illah
yes, sticky on both sides. One side sticks to my fingers, the other side to the trash can :D
