- Oct 16, 2002
Hello everyone,
I just finish my water cooling system in line and was wondering if the temps are normal right, I water cooled my cpu and gpu!
the system is:
a7v333 non raid
amd 2200+
512m pc2700 samsung
80g wd 8m cache
radeon 9700 pro
audigy gamer
350w enarmax
wc system is:
maze 3 block
Swiftech 50 gpu block
eheim 1250
dteck heater core with one set of shroud and 120mm fan-pull
1/2" tygon tubing
as3
pump>rad>cpu>gpu>T-line> and back to pump
ok, I overclock my amd [email protected]*184=2116 with a volt of 2.0 and my radeon [email protected] 400/370...I get in die 42c idle and 48c load, is this alright or it should be lower...
"edit"
I just open my windows and my room temp is 21c, so now the overal temp drop by 4c, now 38c idle, and 44c load
the system is:
a7v333 non raid
amd 2200+
512m pc2700 samsung
80g wd 8m cache
radeon 9700 pro
audigy gamer
350w enarmax
wc system is:
maze 3 block
eheim 1250
1/2" tygon tubing
as3
"edit"
