(title)
G GOD Member Joined Apr 26, 2001 Location The land down under...LOL.. Jun 25, 2001 #2 never use top motor fans for your cpu hsf. or else one that u`ll be left with a very crisp chip!. one day is a understatement! GOD....
OP M Mav Registered Joined Jun 21, 2001 Jun 25, 2001 Thread Starter #3 ?!!? you can't use them on an HSF??? Im getting a WBK38 w/ 80mm Top Motor fan...41CFM. And I'll also install another Top Motor (36CFM) as an intake fan... why wont the Top Motors work as HS fans??
Paul -The Mad Hatter Member Joined Apr 20, 2001 Location santacruz county, ca Jun 25, 2001 #4 Mav (Jun 25, 2001 12:07 p.m.): ?!!? you can't use them on an HSF??? Im getting a WBK38 w/ 80mm Top Motor fan...41CFM. And I'll also install another Top Motor (36CFM) as an intake fan... why wont the Top Motors work as HS fans?? Click to expand... yeah, good question. I've got one on my gladiator.
T Tachyon Senior Member Joined Jan 7, 2001 Location Arkansas Jun 25, 2001 #5 I'm less than impressed with the quality and apparent MTBF on these fans.
OP M Mav Registered Joined Jun 21, 2001 Jun 25, 2001 Thread Starter #6 i dont imagine GOD is correct...and if he is, that WBK comes with a delta screamer...soooo ill b ok lol u didnt like the quality? ppl over at anandtech said the top motor fans were a great value if you arent looking to spend 30 bucks on 3 fans
T Tachyon Senior Member Joined Jan 7, 2001 Location Arkansas Jun 25, 2001 #7 My point was simply to compare engineering specifications such as nominal operating temperatures, MTBF, etc. before deciding what the true value is.
