Argh, US > UK voltage adapter....
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Okay,
I recently purchased an Aluminium Resevoir with an externally mounted 400GPH Aquavia pump from Luefkentechnologies.com, only to realise that its 110V US voltage.
Now we in the UK use 240V, I need to be able to use this pump on UK voltage, so I ring the local electrical store.
All the adapter needs is to be 15Watt+ rated (maximum output of the pump), they have one $5, but its for PC's, and its non-continual use.
They say for a pump that I have, go to a Garden Centre for a special CONTINUAL (24/7) adapter.
Man! I'm nearly skint ($10) and I need this adapter!!!
The only other place I found with one was $100!!!!!
Where can I get one of these and how much?
Not only that they then confuse me saying every state in the US has different Watts. So I will need to tell them which state I got it from to use it?????????????????:eh?:
I hate being in the UK!!!!!!!!!!!!!!!!!!!!!:argue:
Thanks again guys,
Now I can continue helping you!
Nick "Maximus Nickus":)
Diggrr
Underwater Senior Member
All the U.S. states use the same voltage, and the device would draw the same current everywhere here, so the wattage would not change from state to state.
Most devices made in the U.S. will also run fine with the 50htz instead of the 60htz in the U.S.
Sounds like the person that told you that needs some education.
Feel free to print this and tell 'em I said so!
Here's a link to a good voltage converter. The first one on the page will do what you need, with room to spare, and only $17 USD.
Diggrr
Yes, the one on top.
It converts both ways too, so if you ever go to a LAN in the States, you'll be all set.;) (kidding, but it is good and cheap)
Diggrr
You can search for power converters too on Google.com. That's how I found this company, but I couldn't find sites in the UK for you. Maybe with a little more persistence....
The Overclocker
Milton Keynes, UK
nick - maplins sell a volatge adaptor - and we dropped down to 230v about 10 years ago.
and AC power does not have a specific Wattage, it is just the ammount of energy used up by the pump.
CrystalMethod
Senior Band Wagon Jumper
Montreal, Quebec, Canada
You could try seeing what a local electronics shop would charge to change the transformer inside, to convert it to the required voltage. I had to do the reverse with my guitar amplifier. It originally came from Australia, so I took it to a local shop and fo $30 Canadian, they swaped out the transformer for me.
The Overclocker
Milton Keynes, UK
nick - argos sell an adaptor for over 100 countries, it is code number 982/7459 and costs £4.99 (may not be there any more - i am looking at the old catalouge)
maplins also sell a universal traval adaptor (£4.99) code number: BN30H
they look like the same thing.
Maximus Nickus
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Great idea!
Maximus Nickus
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Thanks for looking I really appreciate it. Unfortunately the new Argos Catalogue doesn't have it:(
And Maplins have dis-continued it!!! ARGH!!!
I'll double-check tommorow!
