Hey all, long time no see.
I come before you today with a very annoying problem.
After the latest major ARK update, I wanted to check out the new additions, however I can't seem to keep my game running as it crashes after 5-10 minutes after loading the map.
I already analyzed the latest dump file with WinDBG, but it seems that's as far as my knowledge goes.
I already verified the file integrity, reinstalled the game and updated my GPU driver, I'll be reinstalling again in a few + deleting any leftover files in the Steam common folder.
For system specs, check my siggy.
The analyzed dump file:
Any help would be appreciated
Code:
Microsoft (R) Windows Debugger Version 10.0.10586.567 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\Steam\steamapps\common\ARK\ShooterGame\Saved\Logs\Dump-2020368528.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: srv*
Executable search path is:
Windows 7 Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Sun Jul 31 11:03:25.000 2016 (UTC + 2:00)
System Uptime: not available
Process Uptime: 0 days 0:10:24.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(270.1bf8): Access violation - code c0000005 (first/second chance not available)
ntdll!NtGetContextThread+0xa:
00000000`77001fea c3 ret
0:000> !analyze -v
* Exception Analysis *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for nvwgf2umx.dll -
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
CONTEXT: (.ecxr)
rax=4078b46ab3b00000 rbx=00000000248bed80 rcx=93e1c3b2f82b0000
rdx=000000000059df70 rsi=0000000000000000 rdi=000000000059e0c0
rip=00000001408e616d rsp=000000000059e050 rbp=00000001705ef600
r8=000000000000ffff r9=000007feec690000 r10=00000000248beda0
r11=0000000000000000 r12=000000000059e160 r13=00000000248bd768
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010206
ShooterGame!opus_repacketizer_out_range+0x147431d:
00000001`408e616d 488b5028 mov rdx,qword ptr [rax+28h] ds:4078b46a`b3b00028=????????????????
Resetting default scope
FAULTING_IP:
ShooterGame!opus_repacketizer_out_range+147431d
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 00000001408e616d (ShooterGame!opus_repacketizer_out_range+0x000000000147431d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
DEFAULT_BUCKET_ID: INVALID_POINTER_READ
PROCESS_NAME: ShooterGame.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: ffffffffffffffff
FOLLOWUP_IP:
BUGCHECK_STR: INVALID_POINTER_READ
WATSON_BKT_PROCSTAMP: 579d7ce5
WATSON_BKT_PROCVER: 4.5.1.0
PROCESS_VER_PRODUCT: Unreal Engine
WATSON_BKT_MODULE: ShooterGame.exe
WATSON_BKT_MODSTAMP: 579d7ce5
WATSON_BKT_MODOFFSET: 148616d
WATSON_BKT_MODVER: 4.5.1.0
MODULE_VER_PRODUCT: Unreal Engine
BUILD_VERSION_STRING: 6.1.7601.17514 (win7sp1_rtm.101119-1850)
MODLIST_WITH_TSCHKSUM_HASH: 533e3ad3334908b89bad48e85c9993403520f349
MODLIST_SHA1_HASH: 71d10f255b863889dae59f7a40dcc65ff228c429
DUMP_FLAGS: 0
DUMP_TYPE: 2
APP: shootergame.exe
ANALYSIS_SESSION_HOST: KISSA-PC
ANALYSIS_SESSION_TIME: 07-31-2016 11:21:19.0473
ANALYSIS_VERSION: 10.0.10586.567 amd64fre
THREAD_ATTRIBUTES:
PROBLEM_CLASSES:
Tid [0x1bf8]
Frame [0x00]: shootergame!opus_repacketizer_out_range
LAST_CONTROL_TRANSFER: from 00000001408cbf26 to 00000001408e616d
STACK_TEXT:
00000000`0059e050 00000001`408cbf26 : 00000000`248be7b0 00000000`248be7b0 00000000`00000000 00000000`0059e0d0 : ShooterGame!opus_repacketizer_out_range+0x147431d
00000000`0059e090 00000001`408cbf26 : 00000001`705ef9c0 00000000`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e130 00000001`408cbf26 : 00000001`705ef210 00000000`00000018 00000000`00000001 00000000`00000004 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e1d0 00000001`408e5acc : 00000001`705ef150 00000000`00000018 00000000`00000000 00000000`00000004 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e270 00000001`408cae5b : 00000000`00000000 00000000`00000000 00000000`00000018 00000000`248bf4a0 : ShooterGame!opus_repacketizer_out_range+0x1473c7c
00000000`0059e2a0 00000001`408cbf26 : 00000000`00000001 00000078`0000c3bb 00000000`00000018 00000001`3fe5a3d8 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e2d0 00000001`408e5acc : 00000001`705ef180 00000000`00000018 00000000`00000000 00000000`00000004 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e370 00000001`408cae5b : 00000000`00000000 00000008`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x1473c7c
00000000`0059e3a0 00000001`408d56c7 : 00000000`248bdc08 00000000`00000004 00000000`0059e690 00000000`0059e520 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e3d0 00000001`408cbf26 : 00000000`248bf390 00000079`0000c3bb 00000000`0059e770 00000000`248bfbe4 : ShooterGame!opus_repacketizer_out_range+0x1463877
00000000`0059e420 00000001`408e65f7 : 00000000`248be370 00000000`0059e770 00000000`00000000 00000000`0059e520 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e4c0 00000001`408e65f7 : 00000000`00000000 00000000`248be6d0 00000000`0059e770 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14747a7
00000000`0059e500 00000001`408e65f7 : 00000000`00000000 00000000`248bdad8 00000000`0059e770 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14747a7
00000000`0059e540 00000001`408e65f7 : 00000000`00000000 00000000`248be698 00000000`0059e770 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14747a7
00000000`0059e580 00000001`408e5acc : 00000000`248bf9d0 00000000`248bedb0 00000000`0059e770 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14747a7
00000000`0059e5c0 00000001`408cae5b : 00000000`00000000 00000000`15010100 00000000`15014980 00000000`248bd520 : ShooterGame!opus_repacketizer_out_range+0x1473c7c
00000000`0059e5f0 00000001`408d56c7 : 00000000`248bfa98 00000000`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e620 00000001`408e65f7 : 00000000`00000000 00000000`00000000 00000000`248bede4 00000000`248bedb0 : ShooterGame!opus_repacketizer_out_range+0x1463877
00000000`0059e670 00000001`408e5acc : 00000000`248beec8 00000001`705ef1e0 00000000`0059e770 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14747a7
00000000`0059e6b0 00000001`408cae5b : 00000000`00000000 00000000`0059e770 000093e1`c3eb1e6b 00000001`00000000 : ShooterGame!opus_repacketizer_out_range+0x1473c7c
00000000`0059e6e0 00000001`408e5606 : 00000000`00000000 00000000`248bdb10 00000000`00000018 00000000`248bef30 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e710 00000001`408cbf26 : 00000000`00000001 00000000`248bef30 00000000`00000018 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14737b6
00000000`0059e740 00000001`408cbf26 : 00000001`705ef120 00000000`00000018 00000000`00000001 00000000`00000004 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e7e0 00000001`408e5acc : 00000001`705ef5a0 00000000`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059e880 00000001`408cae5b : 00000000`00000000 00000000`248bd768 00000000`248bd520 00000001`4210cae0 : ShooterGame!opus_repacketizer_out_range+0x1473c7c
00000000`0059e8b0 00000001`408cae5b : 00000000`00000000 00000001`3fe59180 00000000`005aeb67 00000001`4210cae0 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e8e0 00000001`408cab12 : 00000000`0059eac0 00000000`248bd520 00000000`00000000 00000001`3fe0c90c : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059e910 00000001`408cab12 : 00000000`00000000 00000000`248bee28 00000000`00000000 00000001`3fe5a3d8 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059e940 00000001`408cab12 : 00000000`00000000 00000000`248bea98 000093e1`c3eb10db 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059e970 00000001`408cab12 : 00000000`00000000 00000000`248be840 00000001`41d5aa80 00000000`00000100 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059e9a0 00000001`408cab12 : 00000000`00000000 00000000`248beb10 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059e9d0 00000001`408cab12 : 00000000`00000000 00000000`248bebf0 00000000`00000000 00000008`00000000 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059ea00 00000001`408cab12 : 00000000`00000000 00000000`248beca0 000093e1`c3eb11bb 00000001`40913c9b : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059ea30 00000001`408cae5b : 00000000`00000000 00000000`248bebc0 00000000`00000000 00000000`248be8f0 : ShooterGame!opus_repacketizer_out_range+0x1458cc2
00000000`0059ea60 00000001`408cbf26 : 00000000`00000000 0000007d`0000c3bb 00000000`00000000 00000001`408c1da4 : ShooterGame!opus_repacketizer_out_range+0x145900b
00000000`0059ea90 00000001`408e4ff9 : 00000000`0059ebd9 00000000`00000000 00000000`0059eba0 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x145a0d6
00000000`0059eb30 00000001`408bb48d : 00000000`00000000 00000000`248bd520 00000000`248bd520 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x14731a9
00000000`0059eb60 00000001`4072752d : 00000001`705a4c80 00000001`705a4c80 00000001`705a4cb0 00000001`ffffffff : ShooterGame!opus_repacketizer_out_range+0x144963d
00000000`0059ec40 00000001`40727baf : 00000001`705a4c80 00000001`40727b04 00000001`705a4c80 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x12b56dd
00000000`0059ed10 00000001`40739f51 : 00000001`705a4c80 00000001`707af240 00000000`0059ee39 00000001`40471008 : ShooterGame!opus_repacketizer_out_range+0x12b5d5f
00000000`0059ed50 00000001`40727d8b : 00000001`705a4cb0 00000001`705a4c80 00000000`802ba638 00000000`54504948 : ShooterGame!opus_repacketizer_out_range+0x12c8101
00000000`0059edc0 00000001`4072d89d : 00000001`705a4cb0 00000000`00000000 00000000`00000002 00000001`705a4cb0 : ShooterGame!opus_repacketizer_out_range+0x12b5f3b
00000000`0059ee40 00000001`4047f951 : 00000000`00000000 00000001`3f550290 00000001`67cbea70 00000000`802ba600 : ShooterGame!opus_repacketizer_out_range+0x12bba4d
00000000`0059eea0 00000001`408088ec : 00000000`81393d00 00000000`060ea5d8 00000000`81393d38 00000000`060ea5e8 : ShooterGame!opus_repacketizer_out_range+0x100db01
00000000`0059eee0 00000001`3fcf6df6 : 00000000`802ba600 00000000`000000c0 00000000`060ea5c8 00000000`81393d00 : ShooterGame!opus_repacketizer_out_range+0x1396a9c
00000000`0059ef20 00000001`3fcf68dd : 00000000`0059f070 00000000`060ea5c0 00000000`00000001 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x884fa6
00000000`0059efa0 00000001`3fcf7d0d : 00000000`15029700 00000000`00000000 00000000`00000000 00000000`8125fe00 : ShooterGame!opus_repacketizer_out_range+0x884a8d
00000000`0059efd0 00000001`3fda60b1 : 00000000`00000000 00000000`00000000 00000001`4219aab0 00000000`d153db00 : ShooterGame!opus_repacketizer_out_range+0x885ebd
00000000`0059f050 00000001`407d2672 : 00000001`4cca7000 00000000`00000000 00000000`ffffffff 00000001`4cca7000 : ShooterGame!opus_repacketizer_out_range+0x934261
00000000`0059f0d0 00000001`407d70ea : 00000000`15029700 00000000`00000000 00000000`00000001 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0x1360822
00000000`0059f160 00000001`40628a2b : 00000000`00000000 00000000`14b36a40 00000000`00000002 00000000`00000001 : ShooterGame!opus_repacketizer_out_range+0x136529a
00000000`0059f1c0 00000001`40629daa : 00000000`14b36a40 00000000`14cee420 00000000`14cee420 00000000`00000001 : ShooterGame!opus_repacketizer_out_range+0x11b6bdb
00000000`0059f1f0 00000001`40558b5c : 00000000`14b36a40 00000000`02293480 00000000`00000000 ffffffff`fffffff8 : ShooterGame!opus_repacketizer_out_range+0x11b7f5a
00000000`0059f310 00000001`3f54bbb9 : 00000000`16dee9c0 00000000`00000000 00000000`00000000 00000001`00000000 : ShooterGame!opus_repacketizer_out_range+0x10e6d0c
00000000`0059f460 00000001`3f5461dc : 00000000`00752dac 00000000`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0xd9d69
00000000`0059f630 00000001`3f54d09a : 00000000`00000000 00000000`00752d1a 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_out_range+0xd438c
00000000`0059f6d0 00000001`3f54d1c8 : 00000000`00752d1a 00000000`00000000 00000000`0000000a 00000000`007b1420 : ShooterGame!opus_repacketizer_out_range+0xdb24a
00000000`0059f710 00000001`416e0931 : 00000000`007536e9 00000000`0000000a 00000000`0000000a 01d1eb08`f35f6e2a : ShooterGame!opus_repacketizer_out_range+0xdb378
00000000`0059f750 00000000`76ea652d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ShooterGame!opus_repacketizer_get_nb_frames+0x28f511
00000000`0059f790 00000000`76fdc521 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : kernel32!BaseThreadInitThunk+0xd
00000000`0059f7c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x1d
THREAD_SHA1_HASH_MOD_FUNC: 7e805dcceaf414aaa109a3ff30381bd4fe2b1f8a
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 73f8e1a71bdbe4213a1cc0cb61e3b425b28ce728
THREAD_SHA1_HASH_MOD: 91d05ead2c194d43566375e8d2a31ede18e53273
FAULT_INSTR_CODE: 28508b48
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: shootergame!opus_repacketizer_out_range+147431d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ShooterGame
IMAGE_NAME: ShooterGame.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 579d7ce5
STACK_COMMAND: .ecxr ; kb
FAILURE_BUCKET_ID: INVALID_POINTER_READ_c0000005_ShooterGame.exe!opus_repacketizer_out_range
BUCKET_ID: X64_INVALID_POINTER_READ_shootergame!opus_repacketizer_out_range+147431d
PRIMARY_PROBLEM_CLASS: X64_INVALID_POINTER_READ_shootergame!opus_repacketizer_out_range+147431d
BUCKET_ID_OFFSET: 147431d
BUCKET_ID_MODULE_STR: ShooterGame
BUCKET_ID_MODTIMEDATESTAMP: 579d7ce5
BUCKET_ID_MODCHECKSUM: 2f3f9bc
BUCKET_ID_MODVER_STR: 4.5.1.0
BUCKET_ID_PREFIX_STR: X64_INVALID_POINTER_READ_
FAILURE_PROBLEM_CLASS: INVALID_POINTER_READ
FAILURE_EXCEPTION_CODE: c0000005
FAILURE_IMAGE_NAME: ShooterGame.exe
FAILURE_FUNCTION_NAME: opus_repacketizer_out_range
BUCKET_ID_FUNCTION_STR: opus_repacketizer_out_range
FAILURE_SYMBOL_NAME: ShooterGame.exe!opus_repacketizer_out_range
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/ShooterGame.exe/4.5.1.0/579d7ce5/ShooterGame.exe/4.5.1.0/579d7ce5/c0000005/0148616d.htm?Retriage=1
TARGET_TIME: 2016-07-31T09:03:25.000Z
OSBUILD: 7601
OSSERVICEPACK: 17514
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 7
OSEDITION: Windows 7 WinNt (Service Pack 1) SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2010-11-20 14:05:15
BUILDDATESTAMP_STR: 101119-1850
BUILDLAB_STR: win7sp1_rtm
BUILDOSVER_STR: 6.1.7601.17514
ANALYSIS_SESSION_ELAPSED_TIME: de39
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:invalid_pointer_read_c0000005_shootergame.exe!opus_repacketizer_out_range
FAILURE_ID_HASH: {22ad21c8-d295-65bc-be35-07426c3d1cea}
