Same. I just don't like to see a lot of meat left on the bone, lol. 80C in a stess test on air seems.......limiting.I like to over build whenever possible.
Just for fun, about 2 months ago I made an estimate on CB R23 score for the top Arrow Lake based on leaked clocks and some assumptions about core performance. My guess was 43450. This was posted on LTT forum as a status update on my profile. I can't link directly to that post but it can be searched or expand attached image for screenshot.
Why bring this up now? There's been a recent leak of scores as follows:
42286 - this result in on hwbot and it is ambiguous if it is really stock as Videocardz claims. The submitter has what looks like hardware adjustment tools in the background of the screenshot, and if benchmate is accurate the CPU is running hot enough there may be throttling going on.
45563 - result at 250W power limit which is the Intel recommended performance profile, so this is more likely "stock" if this result is correct. Temps under 80C so shouldn't be throttling.
46289 - unlimited power limit, peaking at reported 370W, temps up to 90C.
Two more days until we get widespread independent testing.
Unlocked Intel Core Ultra 9 285K approaches 370W power draw during Cinebench test - VideoCardz.com
Intel Core Ultra 9 285K put through extreme testing According to new screenshots shared on social media, the Core Ultra 9 285K will consume between 360-370W when fully unlocked. This power draw can be observed during a multi-core Cinebench R23 test, with all P-Cores locked at 5.6 GHz and all...videocardz.com
yikes, 370w!
At that kind of power I could run 2x 7800x3d's and still produce less heat.
Man... I love so many aspects of Intel. VPro is awesome, quicksync is useful, their iGPUs are honestly very good for non gaming. I really love the T series CPU's for moderate low power applications.Even 3x 7800x3d ... and 9800x3d will be released soon
I wouldn't touch Intel since the first Ryzen release if not for tests and reviews.
That's with no power limit and we don't know if that was a one off peak or how close the average of the run was.yikes, 370w!
Looking again, the linked poster did say "with bios optimisations" but it looks like they kept Intel recommended power limit. The same poster used the 42286 example as unoptimised but that is way above recommended power limit, so can't be stock either. Following the links further didn't shed any more light on the original source of what those optimisations might be.The 45563 score isn’t stock, it’s manually overlocked.
The nearest competitor is the 9950X which has a stock power limit of 230W, so Intel recommended power limit of 250W is not so much different. We'll have to see how they perform at those limits and/or at same power. 2 days...
PPT is usually set 35% over TDP, which at 170W TDP would put it at 230W. I didn't double check it at the time so there's always a chance AMD throws a curveball. Trying to verify that value now, TechPowerUp says it is 225W, Tom's Hardware says it is 230W.9950x stock power limit is 200 W.
CB 2024 is significantly affected by ram performance unlike R23 and earlier which hardly responds to it unless you're after 1% for competitive benchmarking. So if ARL has a better ram subsystem, that could help those scores.I think ARL will perform better in CB24 from the scores that have leaked.
Hallock already stated to expect about 5% behind 7800X3D. If accurate, that would still leave it competitive to Zen 4/5 non-3D. The perf delta is pretty close for a lot of models at the top anyway, so small changes could alter ranking a lot. It is a given that AMD retains the halo position, but the battle could still be won or lost on pricing at the lower tiers. Basically a similar battle AMD GPUs have to face vs Nvidia.In other news, word on the street (twitter) is that ARL's gaming performance is a decent regression from RPL.
I'd imagine the IPC increase rather than the multi-tile latency helps it there. It may be able to run faster... but, it also may need too. I think the uncore is lower between gens too by several hundred Mhz.So if ARL has a better ram subsystem, that could help those scores.
I can't tell you what my results are, but I will share that I have spent an inordinate amount of time double checking them.Hallock already stated to expect about 5% behind 7800X3D. If accurate,
AMD Ryzen 9 9950X Review - The New Flagship
With 16 cores and 32 threads, the Ryzen 9 9950X, powered by AMD’s Zen 5 architecture, is the fastest desktop processor we've ever tested. In our review, it breezed through application workloads and delivered high FPS rates in gaming. But at $650, it doesn’t come cheap.www.techpowerup.com
Looking forward to it.I can't tell you what my results are, but I will share that I have spent an inordinate amount of time double checking them.
In quick further searching, I did find two places stating a 9950X PPT of 200W, but I also found more saying 230W. Do we have an AMD slide or similar stating this anywhere to settle this? I'll search deeper later.It’s 200W. Not sure why they are reporting otherwise.
Without going back to find out exactly what was said at the time, and how it was tested, it is possible to be efficient in some conditions and not others.Hallock also claimed MTL was way more efficient than Zen 4, which was a lie.
Less than that now. Is the embargo time under embargo? I think most tech go live times tend to be early afternoon UK time, which might be 8 or 9am Eastern?You can't tell only for two more days
I didn't like the guy when he was at AMD. I don't know if he's any different now at Intel. That's (technical) marketing for you.
The first rule of review club is: you do not talk about the embargo.
Thanks. I'll take mobo default as an indicator, as AMD have been better than Intel at keeping settings in line. I wonder if those other sites listing 230W did what I did then. I don't recall if there were other exceptions but PPT has been 35% over TDP as far as I can remember.You can check power measurements (it won't go over 200 W at stock) or Ryzen Master which lists the stock PPT at 200 W.
I've been good across the 3 boards I've played with (for what little that is worth).Additionally, there are leaks of significant stability issues (games crashing, BSOD).
I think when we see a wider swath of games the difference won't be as much, but I'd imagine there will be outliers like this...A user at overclockers.uk got his CPU early and has posted a couple of results. The results are really bad, seems like an early BIOS issue (hopefully).
