Hi all I had an intresting experence today.If you see sig you will see the system,That I cooled by close to 7c
Here is what happened I set up My old 1.4 @ 1.53 for the wife.
I had the SK6 with a delta screamer on it, my old case and all the stuff is the exact as it was when I ran it,EXCEPT I installed a Alpha PAL 6035 Heatsink on it this time and used the thermal paste that shipped with the pal 6035.It is her email system so I dident get too fussy with it.
Temps prior On that box with Artic silver 2 and the SK6 maxed at 52c.This ****ed me off bad so I reinstalled the heat sink many times with the Artic 2, tried more paste tried less,Installed a skim coat and installed a heavy layer but it always ran at 52c max.
The alpha Pal 6035 With the screamer and stock paste MAX AT 41c,That ****ed me off badly I removed the screamer 38cfm jet engine from the pal and installed its stock fan,TEMPS ARE 46C MAX !!!
Now my dual rig you see below was hitting 45c and 47c on the 2 processors.{Some reason this is common on dual AMD two diff temps}SO after I saw the change on the old rig I installed stock paste on My dualies and reinstalled my screamer 38 cfm deltas.
Temps NOW ARE MAX 40C AND 38C !!
Has any one ever had Artic Silver 2 perform badly ? I have had 3 systems running it and all had temps i thought where High.And after this parade I know my temps had been high on the last 3 because of artic silver 2 !!!!!!
