Also, make sure the HS has a good even seat on the CPU core. Just a hair off can make a big difference in your cooling. Take off your HS and clean it, then with a thin coat on the CPU, reapply the HS, then remove it. if you don't have an even pattern on the heatsink, it isn't sitting level on the CPU
