Powerleap says your board is incompatible - "bios hangup". So I guess your chances are next to nil, since there is not much reason why the bios would hang up if you use the powerleap adapter and not hang up if you use your modded cpu/adapter.
That said, I successfully got it to work on a Asus P2B, which is also incompatible if you ask powerleap (they have now a different bios to make it compatible, which I don't have). But this case is a bit different, because the well-known problem with that board is it has a bios bug which only affects cpus with multiplier 11 and 12 (regardless if it's coppermine or tualatin). Powerleap tested with the 1.2 Celeron, and it didn't boot. But I took the 1.0A and it worked (the 1.3 would work too, but at that time I didn't know this, and I would have taken the 1.0A anyway because it runs at 1330Mhz without hassle)
So, it *might* be possible it works if you use not the same cpu as powerleap used for testing, but I really doubt the gigabyte board has the same stupid bug the asus p2b series has :-(
mczak
