- Nov 30, 2008
. . . . . . . . . The entirety of this post is a fictious parody of what really happens, while persons of the same name and company might exist in the real world, those persons and companies in this post are not the ones in the real world. . . . . .
Me: Hello, tech support please . . .
Them: music - - - - music - - - - music - - - -We think your call is important - - - music - --- music
(30 minutes later on long distance call)
Them: Hi my name is greg, how can i help you today
Me: Hi i have the blinko 88 adapter, and the BIOS that is on the CD you provided will not flash this revision of the card, i downloaded the 2 off the web and they also are not compatable flash roms for this eprom. I am using the blinko flash utility, and i have tried it using Dos also.
Them: Did you try and flash the BIOS from the CD
Me:yes sir, i tried to flash using the ones that came on the CD and it will not work on this revision of the card. I am using the blinko flash utility
Them: Ok you go to web site at WW2Blinko/bios
Me:Yes sir i am at that location now and i do not see any other bios than the ones i have tried from there the software specifically states that the Eprom size is 84k and the flash i am trying to put on is 66k. (or some such thing)
Them: then you must use the one from the cd , and you will have to flash it from dos
Me:is there a possibility that this is the wrong cd , i have revision 74.32 of the card, do you have a rom that will flash to that revision of the card? the Blinko flash utility shows this error (paste in actual error) the dos utility shows the same errror.
Them: You have to use the binko flash utility.
Me:Yes i am using the blinko flash utility , but i have also tried flashing using a dos disk, and it still will not work. do you just think you could check and see if there is a bios for this revision.
Them: Oh no, you cannot flash it from dos, you have to use the blinko flash utility
Me: i have USED the blinko flash utility, and i get this error, i have used the dos utility also, do you have a bios for this revisision revision 74.32 of the card.
(long pause -- music --- click - - - - dead air - - - - -)
wait wait wait, beep beep beep , please hang up and try again
redial
(25 minutes later on long distance call)
Them: Hello blinko tech support.
Me: Hi i was just talking to Greg, can i talk to greg again we got cut off, i think he was checking something for me.
Them: there is no greg in this office , were you talking to bangezze?
Me: no i was talking to greg, look can i talk to your supervisor
(long pause -- music --- music ---- music - - - - -)
Them: Hello this is bangezze, how can i help you today
(it is "Greg" oh well)
Me : I have the blinko 88 adapter rev 74.32 , i am trying to flash to the new bios to fix the card (paste in error)
- - - -(for the sake of brevity, as you all know we go through the first 57 lines of this script all over again)- - - - -
Them: I am very sorry , you have to use the blinko utility to flash
Me:I use the blinko utility , i believe the rom does not work with this card, did you see the error? do you know what that error means? I just need the rom itself to work with that revision. I also tried it in dos it does not work, same error.
Them: You cannot use the blinko utility with that revision of the card, you have to do it in DOS.
Me:I have tried it on dos, i have tried the rom on the cd, and both roms on the web, it seems that the Rom does not fit the eprom on the card, i NEED THE ROM itself that works with revision 74.32 of the card.
Them: then you will have to go to ww2.blinko/bios and download it from there.
Me: i have done that, can i talk to your supervisor or a tech that can help, i have a different revision of the card, it doesnt work.
Them: well you have to use the blinko utility
. . . . . . . . . The entirety of this post is a fictious parody of what really happens, while persons of the same name and company might exist in the real world, those persons and companies in this post are not the ones in the real world. . . . . . .
loooool so true
