as3
toddalaska
use it to rub on open scabs cause it sure doesnt work for cooling
i got identical results with two different types of white goo and a pink one.
they say it needs to be "cured" never worked for me, maybe it just takes a couple of years.
Sorry bout the rant its just the biggest scam ever in computers.
JFettig
Hey! I showered! Senior
MN
alrite if you think so, i have personally had a few degrees, but its not a big deal and it depends on the board you use,if it read the ondie diode then its more acurate, it takes multiple testes to know exactly how well it works
toddalaska
yeah i did a 3 week review with various application techniques.
it does help but not as much as people think.
its definitely not the miracle cure people think it is.
from when i tested a proper (thin) application of generic white stuff will get you within a degree of as3.
where i think as3 may be useful is during cooldown times
it may help get back to your idol temp quicker than the white stuff.
I wasnt that thorugh with that part of the test but it did seem like that
specific
Atlanta, GA
i noticed a 2 degree difference from as2 to as3.
i don't think it's a conspiracy.
but laptops, not being cloned and upgradable, that's a big conspiracy if you ask me.
