Hello everyone
I have an issue with this motherboard in particular the wifi antennas connectors (those golden ones you screw the antennas to) on the back panel basically one of this connectors became loose after tightening the antennas, now I can't really say it is broken but if not how can I fix it? Should I replace the wifi card?
