Asrock x79 Extreme4 & GTX 780: PCIe 3.0 issue again
magellan
I couldn't find the old thread I had dealing w/this issue, but I have more information
now.
When I have the PCIe slots set to Gen3 in the BIOS, I can't boot the system w/my old ATI 6970 (yep it was still ATI when I bought it). If I switch the PCIe slots to Gen2, the system boots. So, it looks to me like the motherboard and CPU (i7 3820) are capable of running at PCIe 3.0.
Does anyone know how I can get Windows 7 or Windows XP Pro to run the PCIe slots in 3.0? I tried the Nvidia patch (which was written to force GTX 6xx series GPU's to use PCIe 3.0 mode) but it didn't make any difference (I tested w/GPUz and used their special utility to put a load on the GPU), the slot still stayed in PCIe 2.0 x16 mode at most (if I close the GPUz utility that loads the GPU it reverts from PCIe 2.0 to PCIe 1.1).
Maybe there's a registry setting I can change to force PCIe 3.0 mode -- kinda like the old nvidia coolbits tweak?
ATMINSIDE
I'm going to pull this from your other thread:
IIRC Sandy Bridge doesn't support PCIe 3.0, only Ivy Bridge.
That post was directed toward both SB and SB-E.
But yes, IB-E should allow PCIe 3.0, because that's when Intel started supporting PCIe 3.0.
wingman99
Sandy Bridge E & X79 PCIe 3.0: It Works
http://www.anandtech.com/show/5264/sandy-bridge-e-x79-pcie-30-it-works
QUOTE:Simply enabling PCIe 3.0 on our EVGA X79 SLI motherboard (EVGA provided us with a BIOS that allowed us to toggle PCIe 3.0 mode on/off) resulted in a 9% increase in performance on the Radeon HD 7970. This tells us two things: 1) You can indeed get PCIe 3.0 working on SNB-E/X79, at least with a Radeon HD 7970, and 2) PCIe 3.0 will likely be useful for GPU compute applications, although not so much for gaming anytime soon.
Woomack
Benching Team Leader
I've noticed that some older gfx cards are simply not working on some new boards with pcie 3.0. You have to boot with some other card and switch it manually to 2.0 or use 2nd pcie slot. However I had only issues with older cards than AMD 6 series.
About the same I had on X79 and Z87 boards but using 2.0 slot is not causing performance drop for anything pre AMD 7900 series.
Software is usually reading pcie mode wrong and correct readings are almost always in 3D/high load. That's why in GPU-Z to check pcie on some new cards, you have to use full screen 3D test.
M
magellan
It's kinda annoying that I have a motherboard that advertises PCIe 3.0, a video card that advertises PCIe 3.0, but I can't do PCIe 3.0.
ATMINSIDE
Because your PROCESSOR doesn't advertise PCIe 3.0...........
M
magellan
There's nothing on the motherboard box that states it only supports PCIe 3.0 if an Ivybridge-E CPU is installed, but it is in the motherboard manual so OBVIOUSLY they know about it.
Alternatively, why doesn't the video card manufacturer put such a warning on the website or on the video card box? After all, it's not like Nvidia doesn't know about it.
ATMINSIDE
Because that would be bad marketing.
Intel lists PCI Express Revision as 2.0 for the i7-3820. That's all the warning you need, as the company that has the product directly responsible for it not being supported has it listed clearly.
Because it isn't their product that isn't supporting PCIe 3.0...
M
magellan
What about the various LGA 2011 Xeons? Do they have PCIe 3.0 capabilities?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Not sure off the top of my head for SB-E based Xeon's, though, I don't believe so. It was IB-E that brought in that support IIRC.
If you google the part, it should return an intel white paper link which you can then find that information out (see RGone's link directly above your last post). ;)
