- Jul 8, 2013
So just acquired an x99 oc formula though unfortunately when I insert my ram (in sig) into slot A1 & B1 per the instructions, it results in error code 19 which sometimes flashes to code b0 (rarely).
I found this with similar issues/same problem, were solved with bios update
http://www.computerforum.com/threads/ram-issue-on-new-build-will-not-boot.237669/
www.tomshardware.com
http://forum.asrock.com/forum_posts.asp?TID=1704&title=x99-extreme-6-code-b0-or-60
I tried all other slots, and using a single stick and swapping them and always get error 19.
With no ram inserted I get error code 19.
Tried switching between bios chips, reset cmos and still the same thing. This ram was working fine before the gigabyte broke though I can't test it as I have no other ddr4 boards/hardware around.
Now I can't upgrade bios to latest version as it won't post with those errors, so I just get something like this to get the board to boot (hopefully)?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148856
All I know is one bios chip has the first broadwell-e bios update, and the other has an older bios with only haswell-e support.
ASRock X99X Killer Fatal1ty Motherboard Error Codes 60 & 19 During POST
I have been unable to get my ASRock X99X to pass the POST no matter what I do. With any DIMMS installed the Dr. Debug shows 60 and 19 error codes. I saw on another website that someone else had the same problem and posted at tomshardware.co.uk forums, but answer 2330210 doesn't exist on here...
