- Oct 5, 2008
- Cumbria (UK)
Tonight I am retiring my trusty old Q6600 as my main rig and it will be used as my fileserver as I have a ASRock Z77 Extreme 4 along with a Intel 2500K arriving in the morning to replace it
The main specs will be:
Mobo: ASRock Z77 Extreme 4
CPU: Intel 2500K
RAM: 4x2GB Crucial Ballistix Tracer 1600Mhz
GPU: NVidia GTX 460
I just have a few questions about the setup since this is the first Intel i-series setup I have built...
1: On the ASRock site it says the board supports "Lucid Virtu Universal MVP technology". Now this sounds great as it stops tearing in games without having to enable Vsync and throttle the FPS. There is a small video on the site where it mentions your screen being plugged into the motherboard instead of the GPU and still using the power of the GPU? Also it mentioned that when your screen is connected to the motherboard your discrete GPU can virtually shut off and just use the IGPU of the CPU to save power.
That being the case I'm not 100% positive if it will be best to plug my screen into my video card or the motherboard itself? Any thoughts?....
2: I already had 4GB of the Crucial RAM so I ordered another 4GB along with the mobo. Will the 1600Mhz speed limit my overclocking headroom? I know back in the Skt 775 days I setup a few machines that had their overclocking potential held back by RAM but I'm not sure if the same rules still apply with the Z77 chipset.
3: ASRock make a big fuss over the "Xfast 555" features on this board. The Xfast LAN and Xfast USB don't really interest me, but the Xfast RAM intrigues me a little. The video on the website shows the software being able to use this feature to store the pagefile in RAM and a few other things I can't remember off hand. So is this feature usefull and if so whats the best way to take advantage of it?
I think that's all the questions I have for now. Makes sense getting advice now before the board arrives so when I get the system built tomorrow I can get strait to the overclocking
5Ghz possible
I sure hope so
CPU: Intel 2500K
GPU: NVidia GTX 460
