ASrock Z790I Lightning Wifi
andreyyq
Hi to you all,
I am currently in the process of trying to get a 14900ks and a kit of teamdata 32gb a die to the limit while cooled by ekwb setup and so on. So far I have managed to squeeze 8000mhz karhu stable, timings are reasonably ok and I have also squeezed the 2nd, 3rd and 4th timings in as much as possible however in order to go further I need to adjust the voltage even further and I am finding it hard to understand exactly the FVIR and where the SA voltage is located? Coming from an Asus APEX ENCORE where the bios settings seem reasonably straightforward, I am finding it fairly difficult to understand the ASROCK bios so any guidance regarding what and what is for SA. Also regardless of the VDDQ and VDD voltage I adjust, the board seems to sort of interfere with what I dial in. Also CPU voltages seem to be automatically regulated although I have disabled as many intel power limits as possible then again the bios options are way different to Asus which I have used up to now?
Thanks.
Hi to you all,
Thanks.
Should I call u mister?
