- Dec 3, 2016
On my motherboard with the latest bios which is 2.40 I can NOT set adaptive voltage without it hitting 1.38 to 1.4v for a few seconds at a time in my core voltage is set at say 1.26. I have all C states enabled and I've been reading for weeks trying to find a solution. Setting a negative offset will lower the spike I think but only 0.3-0.5 max and I still need to check stability. I'm at 4.5Ghz with 1.265v and I'm decently stable in Aida and x264 but not prime which is the newer version.
Even with everything set to energy saving my vid does not lower on static voltage and I can confirm with a kill a watt letter that adaptive voltage setting used about 5 watts less then override voltage setting. Also to add salt to the wound I cannot monitor Vcore on the asrock board afaik.
So should the voltage spikes be ok? I have a h100i and only hit 90c under super heavy linpack.
Should I eat the extra 5 watts and keep static voltage?
Or should I lower my OC to 4.2-4.3 and lower voltage required?
I don't really wanna do static because in my mind that 1.265 continuous will degrade the processor life and I truly don't plan on replacing it for several years unless Intel gets some competition and they release a processor that's significantly faster.
Also does the ring bus overvolt like this on adaptive? Is it truly ok to hammer these with static voltage? I'm seriously debating if its even worth this hassle to overclock but I would LOVE to go farther.
- - - Updated - - -
The CPU in question is a 4670K.
- - - Updated - - -
