ASUS A7M266 SOMETHING FISHY
tandeme
ok i just downloaded the manual from asus for the a7m266 just to see if you can change the multipier in bios, which you can!!, (jumper free mode). now lets say you unlock the L1 it should overclock right? and lets say you increase the fsb with it, if you mod the chip to 1.85 volts (L7 bridges) will that take in the bios also? if all this is right, correct me if im wrong, this would be the best board for overclocking with ddr which has the best chipset right now AMD 761 and is supposidly stable as hell. So why is there this big discussion of the best ddr boards for overclocking and stability ? it seems there is a clear cut winner. if you have a asus a7m266 tell me, DO YOU LIKE IT?
