Asus A7M266 Vcore question
craig
I've tried Overclocking my Cpu but have problems over 1260, I 've had it up to 1350 but when I try to restart it it won't reboot, I wait a few min. then it will work again so I can change it back. My temp. is ok, it hasn't been over 45C yet and my Vcore is at default 1.77V. Do I have to change my VIO1 2.7V default or the VIO 3.30V default? And looking at the manual the Vcore only goes up one more setting to 1.85/1.825V. I want to OC the best I can being stable and under 50C can someone give me some tips and advice about raising the voltage, I am a newbie at this but want the best performance. And also on my vid card I see alot of posts that people with the ultra's raise there memory clock from 460 to around 500 to 530, I raise mine to about 510 to 520 but I'm afraid to check the box that say's start computer with these settings in case the comp doesn't reboot afterwards, any advice on this.
Thanks
Have you tried penning the L7's all in.
There are better, cheaper and faster DDR boards by other companies that go upto plus 0.4v!!!! nevermind!!!!
wild_andy_c (Jul 04, 2001 02:29 p.m.):
No I haven't penned them in, and this is the board I have.
