ok... for everyone's info.. this is my system...
300w ATX Powersupply.
FOP38 w/ grease (we dont have arctic silver here!!)
Athlon TB 750 Green Core (o/c to 950)
Asus A7V Rev 1.04 w/ BIOS 1007
3dfx Voodoo Banshee AGP
2 Maxtor HDD
Case cooling 1 fan blowing air in. another blowing air out. all cables tied properly together!
Misc. Info:
1 Realtek 8029AS Ethernet card
256MB SDRAM
1 Sony E140 CDRW
1 AOpen 10x Slot In DVDROM
Yamaha 754 PCI Sound card
Room temp is 30C (we are in a tropical country). Case temp 35C Processor 47C to 51C
About d BIOS, when i bought the mobo it used the 1004D bios but i changed it to 1007. I/O Voltage is now at 3.3 but i tried 3.65 both no go for 1gig.. i tried 105FSB on BIOS, no go... even DIPSWITCH 105mhz on revision 1.04 Mobo still no go =( what else... hmm..
so i've already has most of the things u recommend except for the jumperfree situation.. i just put it at 133mhz in the past... i tried 110 on the dipswitch but the thing still post at 100mhz x 9.5 ... do i need to unlock another set of bridges??
AZZKICKER (Apr 08, 2001 10:40 p.m.):
lets see if i can help you
bios 1004d is the best bios ive used for OCing and performance
make sure your jumper on the board it set to jumper mode and not jumper free
with my A7V i had to run my I/O voltage @ 3.5 volts at any fsb setting above defalt so try that
also i hope your useing a good heatsink/fan and running temps below 50C
use thermal paste and not thermal pads
good case cooling and a 300+ watt power supply
hope this helps
