Does anyone know the appropriate PLL-IC setting for Asus A7V-E in SoftFSB ? Or isn't that one supported ?
In other words - what PLL-IC does Asus A7V-E use ?
Thanks.
Soft FSB has been discontinued as a point of task of it's own uselessness. If any board is uncapable of doing overclocked speeds, it won't have jumpers or BIOS settings to do them anyway - as such Soft FSB would be futile.
Remember that the A7VE is no overclocking board - it's a budget board based on a chipset that is honed for performance at two bus speeds and two bus speeds only.
I've had my 800 stable at 1100 on that board
Even if it's not designed for overclocking, I will be overclocking - the whole point of SoftFSB for me, is easier overclocking. The FSB frequency dipswitch is placed on a stupid place - you have to remove your cdroms in order to access it. (In my case at least - with a miditower.) That's why I wanted SoftFSB.
Thanks for your input tho
I found some IC's that could read my correct FSB, will it harm anything if I try to set my fsb with those ?
Thanks.
