Asus A7V133-C Bios V.1005A , Problems with adjusting Core Voltage in JumperFree Mode
QN
well, when I adjust the Core Voltage in the Bios it seems that it works, but when I checked it with Asus Probe it shows always 1.68 V ... ok,perhaps this is a bug I thought and tried to run my Duron with undervoltage at 1.1 V and it worked fine, so I think the Bios option doensn´t work, what do you think, or realized by yourself ?¿?
Well, this may not be of much help!
I just got an A7V133 about 3 days ago and am trying out the jumperless settings. I am at 1.6v Vcore, although as ususal the sensor reports higher(1.648). Duron700 at 856(107*8.0).
I saved the original bios as soon as I got a good post and it is still on the ver 1004. You may want to go back to that version and see if the problem persists.
Also, are the jumpers for the Vcore and JEN set to default? I was trying different things in the jumper mode and when I went back to Jumperless, I forgot to set the Vcore to default. Caused some eratic behaviour on my board.
i dont know if i heard this or just thinking of it out of nowhere
i believe i read somewhere the L7 bridges have something to do with core voltage
not sure tho maybe someone else can help you out
hmm, I think this with the L7 Bridges are right, but I don´t have to close them to adjust CoreVoltage or ? the Jumpers are in default settings, so everything should run in JumperFree Mode. I didn´t tried it with Jumpers ( I hate this nasty things) , but I think I´ll first try the new Beta Bios 1006.01A ... =)
