- Apr 29, 2001
ARGH!!!
That fan which came on the motherboard to cool the VIA chipset north bridge is, to paraphrase Gene Rayburn, "a piece of blank!" When powering up, I have to nudge a fan blade a couple of times - then the rotation starts.
I've noticed it gets very warm in the motherboard cavity of the case and I've recently had problems using the serial ports on my computer and not being able to see my new external modem which had worked earlier in the same day. (So I powered and unplugged the lot, and the next morning I powered up & everything worked fine. So I know it's overheating that was causing the problem.)
Where can I get a replacement fan? Or should I get some thermal glue, and glue on my own heatsink/fan combo? I've got tons of small heatsinks and fans laying around...
Until I see something more worthy of concern, I don't think it's necessary to get an RMA on my 2 month old mobo. The system still runs quite stable otherwise.
Thanks!
Thanks!
