ASUS A8N SKI Deluxe ocablity
I have the same mobo and I'm stuck at 1.500 volts maximum so I can only get to 2.76GHz from my Athlon 64 X2 4800+. The manual says that it should go up to 1.560 volts. I can't wait to get my A8N32-SLI Deluxe back from RMA any month now. That board goes up to 1.760 volts!!!:drool:
Hey sephiroth, you linked to the ASUS A8N32-SLI Deluxe. If this is the board you're talking about, then I have to say I luv mine :D I had the Asus A8N-SLI but it lacked the vcore and some ram settings to really oc. It still is a nice board tho, but I prefer the ASUS A8N32-SLI Deluxe over the A8N-SLI Deluxe as the A8N32 has more features to tweak.
ah sorry its not the a8n32 sli deluxe its just the a8n sli deluxe
now i should have the right link i didnt relize there was a diffence unlit awhlie back i never changed the link
how high can the vcore go to on this board
As i remember on mine the max vcore was 1.55v in the bios.:-/ Since it overvolted a tad the asus probe and bios would show 1.62v. Not all boards will overvolt tho. If you wanna go for the high cpu oc, you'll be better off with the DFI.
so if it overvolts will it run 1.6 if you have ti at 1.5?
already paid for and i couldnt pass the deal up plus its just a light to mild oc not a massive one.
Maybe, the big question is IF it overvolts. Keep your fingers crossed and hope it does. Worse case cenario is it'll overvolt maybe to 1.57-1.6v, that's pretty much it. The vdimm will go up to 3.1v tho which is dumb. Why design a board that the vcore's max is 1.55v, yet the vdimm goes all the way to 3.1v? I don't get it:confused:
Anyways good luck , i hope you got a winner. Post back with results!
