1010.1 bios for Asus A8N-SLI?
"Bios 1010.001 Beta
The 1010 series welcomes back all the memory timings which were hidden in previous bios'es due to some incompatibility issues which are now fixed. Some stability as the 1009.002 beta so if you have the 1009 beta, its recommended you step up to the 1010 beta."
Hi. Wanna say thanks for the time put into this sticky. It's helped a lot.
I've got two questions that I'm not sure of:
1. Will the bios rev 1010.001 work on an AN8-SLI premium?
2. What flasher should I use to flash it?
The post at Rebel's Haven said to use bios flasher 1.11. However, I can't seem to find that flasher any where. Can I use the 109 or 108 flasher?
Thanks again for all your help.
Sincerely,
Duneadan
"Bios 1010.001 Beta
Sincerely,
Duneadan
