I have a ryen 1800x with a Asus C6H motherboard and 32gb g.skillz 3200 cass 14 ram. I'm using I think 0902 revision of the bios. I can barely do anything with this board. It won't let me change the multiplier, it won't let me change the voltage to the cpu, it won't let me change the ram voltage. All these fields are grayed out in the bios. The only way I was able to overclock it to 4.0ghz was by using some built in profile and I was able to change the dram frequency from the default of 2133 (i think that was default, not sure) to 2666 which is as high as it'll go and still post. I'm guessing I can't get to 2933 or 3200 because the ram voltage is greyed out at default. What do I need to do to be able to set this bios up correctly and get out of these locked in values?
