Hello, so my story is this that i had this card for 1.5 year and started to not display full resolution, if you set it just throws error that it can't maintain it, so i tested on next pc same results, well i though i will loose nothing i put it in oven and guess what it works flawlessly, but after some testing i noticed that capacitors in the front near cooling pod there is missing cap and remaining 3 in bad shape, problem is i'cant find identical ones to replace.
Letters on caps:
FP5K
2YAh
271
16
Any possible analogs or even improve current ones?
Letters on caps:
FP5K
2YAh
271
16
