hello
i bought the Helios GX01, i want to build a custom LC (done this twice in the past) but am wondering for this case how many rads to go with,
front got 3x 120mm fans and i can mount a rad there
same goes for the top 3x 120mm fans and a second rad can be there or a 240mm rad only
rear SINGLE 120mm exhaust
my concern is IF i setup both FRONT and TOP full size rads,
http://grabilla.com/0b504-2b80ab25-2a7b-4031-95aa-06f791f5bc50.png
what should be the fan directions ?
should BOTH RADS push hot air INSIDE the case ? (pull cool air from OUTSIDE)
will a single 120mm exhaust fan then be sufficient to exhaust all that hot air outside the case ? and wont that increase temps for RAM, board etc ?!...
is it a BAD idea to setup one rad to pull cold air from out-to-in
and the other rad to pull THAT hot air from in to out ?...
i saw those utubers doing those builds
what fan/rad setup and configuration should i go with ?...
thanks,
thanks,
