- Jul 5, 2008
- CFL
So... we sent in 4 P5KPL-CM motherboards to RMA. Some did not post, while the rest had issues not recognizing hard drives, etc...
So we sent them all in to Asus for replacement/repair.
In the end, out of the 4 replacements, one was actually good. The other three were replacements but had problems, too. Each of them unique...
1. Bad temp sensor - would report CPU temp and chipset temp as 200Celcius. BIOS update/downgrade did not help.
2. Would not detect hard drive/optical drive - same motherboard we sent back as it matched the serial number of the original, yet their invoice declared it was replaced.
3 Eight swollen capacitors - yes, eight swollen capacitors. One was leaking, the rest were bulging.
My god, asus! This is unacceptable!
This isn't the first time this has happened... We had issues like this when they released the p5RD2-VM, which was plagued with design defects (over-heating mosfets that would cause RAM to fail tests and BSOD), every board they sent back to us from replacement said it was working... We had a 40% failure rate.
Then the issue with the P5N32-E SLI.... 60% failure rate.
I have yet to purchase an Asus board and these are the reasons why... both in the high-end sector and the low-end sector of their product line.
I've been noticing a decline in their service and quality in the past 5 years.
/end rant
/end rant
