ASUS MAXIMUS 3 GENE MOTHERBOARD, sharing my friend new toy
likeHW99
This motherboard is me chooses for the friend, Therefore I have obtained the priority to try...yeah!
packing:
mb:
cpu VRM using 8+2 phase motherboard power supply all SMD Choke(Bears the big electric current, low impedance) , MOSFET whit Heat Pipe and Extrusion aluminum design heat sink. I/O have EMI eliminator resist interference.
memory 2 phase, whit Go_Botton/MemOK! switch, 24-pin power input filter using High-grade Choke.
2 x PCIe 2.0 x16 (support single at x16 or dual at x8/x8 mode), 1 x PCIe x4, 1 x PCI 2.2 slots.
You might find many SMD Choke on MB( ROG Series Characteristic XD)
SupremeFX X-Fi 8-channel High Definition Audio CODEC Support EAX Advanced HD 4.0. , vicinity have great quantity caps.
rear panel I/O, 1: Clr CMOS Switches, 2:ROG Connect this is a new function( Monitor the status of your desktop PC and tweak its parameters in real-time via a notebook...), 3: this is port for ROG Connect.
750 oc 4g + ddr3 2000 cl9 and biso setting :
20x200 Hyper PI 32mb pass :
http://i492.photobucket.com/albums/rr287/for_sure55/RG320x200HyperPI1a.jpg
Everest 4gb + 2000 C9 Memory Read
http://i492.photobucket.com/albums/rr287/for_sure55/Everest4gb2000C9MemoryReadRG31a.png
Everest 4gb + 2000 C9a Memory Write
http://i492.photobucket.com/albums/rr287/for_sure55/Everest4gb2000C9aMemoryWriteRG31a.png
bios setting :
http://i492.photobucket.com/albums/rr287/for_sure55/RG3BIOS11.jpg
http://i492.photobucket.com/albums/rr287/for_sure55/RG3i57504gddr32000c91.jpg
http://i492.photobucket.com/albums/rr287/for_sure55/RG3i57504gddr32000c9A1.jpg
http://i492.photobucket.com/albums/rr287/for_sure55/RG3i57504gddr32000c9B1.jpg
http://i492.photobucket.com/albums/rr287/for_sure55/RG3i57504gddr32000c9C1.jpg
CPU load, MOSFET and PCH Cera (heat sink) temperature test sharing: (room temp 23c)
cpu load temperature by Core Temp :
http://i492.photobucket.com/albums/rr287/for_sure55/RG34GCPULOAD1.jpg
MOSFET and PCH (heat sink) temperature :
http://i492.photobucket.com/albums/rr287/for_sure55/DSCF91501.jpg
http://i492.photobucket.com/albums/rr287/for_sure55/DSCF91471.jpg
Thermometer T1=Mosft, T2=PCH (room temp 23c)
Mosft idle: 33.8
PCH idle: 35.2
http://i492.photobucket.com/albums/rr287/for_sure55/RG3MOSFETandPCHHSIDLE1.jpg
Mosft Load: 38.2
PCH Load: 36.6
http://i492.photobucket.com/albums/rr287/for_sure55/ROGMOSFETandPCHHSLOAD1.jpg
OnBoard SupremeFX X-Fi 8-channel High Definition Audio CODEC in 2 Channel speaker audition sharing: (short film), BTW i using mobile to take only ! XD :
youtube :
Thank you all same taste guy:toast:
