- Oct 16, 2006
This is MY OcThread. It will take me awhile to overclock this machine, and I want a good SAFE overclock. I want to document the process I use, and what people think and say about what to do, where to go, and how to progress. Right now I am having problems finding default settings to start from.
Asus Maximus Extreme
Bios 1302 (Must Download From Asus Site, Asus Update Tool Does NOT show this)
x38 Defaults (as known - Will add more)
NBV 1.25?
Intel Core 2 Quad Q9550 (Yorkfield)
Multiplier 8.5
FSB - 333
Core Voltage - 1.25?
Corsair Memory
Part Number - CM3X1024-1800C7DHX (4 Sticks)
JEDEC #3 666MHz - 9, 9, 9, 24, 33 (SPD Readings) 1.5v
XMP-1800 900Mhz - 7, 7, 7, 20, 41 (SPD Readings) 2.0v
DRAM Command Rate - 2t
NOTE: I can not find this memory on corsairs website so I can not confirm its SPD settings are right. From what I remember the XMP settings are correct.
Tools:
CPU-Z, Prime95 (64-Bit), Intel Burn, OCCT, and Asus PC Probe II
http://www.cpuid.com/cpuz.php
http://www.mersenne.org/
http://www.xtremesystems.org/forums/showthread.php?t=197835 (If this is not the homepage please send me a PM to fix it, or Admin please feel free to edit the link)
http://www.ocbase.com/perestroika_en/index.php
Starting Point (settings)
OC From Memory Level Up - PC3-12800
Multiplier - 8.5
FSB Frequency - 333Mhz (1334Mhz) *Noted later as FSB
FSB Strap to North Bridge - 400Mhz
PCIE Frequency - 100
DRAM Frequency - DDR3 12800MHz *changes with FSB Frequency
Memory Voltage to 2.0v (RAM Specifications)
Primary - 7,7,7,20,4,48,10,5
Secondary- All Auto
CPU Voltage - 1.25 *Default?
CPU PLL Voltage - Auto
NB Voltage - 1.27 *Default 1.25
DRAM Voltage - 2.00v *Corsair Setting
FSB Termination Voltage - 1.2 *Board Minimum
South Bridge Voltage - Auto
Load Line Calibration - Auto
CPU GTL Reference - Auto
North Bridge GTL Reference - Auto
DDR3 Channel A Ref Voltage - Auto
DDR3 Channel B Ref Voltage - Auto
DDR3 Controller Ref Voltage - Auto
SB 1.5v - 1.5v
Results - Max CPU Temp 33c (Intel Burn, Prime 95) - Stable
Clock Speed 2.83
SB 1.5v - 1.5v
Dram Command Rate - 2t
FSB Termination Voltage - 1.2 (Board Minimum)
Point 1
NBVoltage 1.3
FSB 350mhz (CPUZ reports 351), Rated FSB 1405.8
Resulting Core Speed - 2983
Point 2
FSB 370mhz, Rated FSB 1480
Lowered NBVoltage 1.27
Resulting Core Speed - 3145
Prime Stable - Low Temps (Moved onto IntelBurnTest to Warm Up Water)
IntelBurnTest v2.4
*Asus PCProbe is reporting SB 1.10v (1.09), SB2 1.54v. NB1.30v
*Temps CPU 35c North Bridge 33c
*CONCLUSION MORE OVERCLOCKING
Point 3
Note: Jumped to 400mhz (failed to POST)
FSB 380mhz, Rated FSB 1520
Resulting Core Speed - 3230Mhz (9% increase)
Point 4
FSB 390mhz, Rated FSB 1560
Resulting Core Speed - 3315Mhz (10% increase)
* 2 Hour Prime Test - Temps Under 37c - No Failures
History: I am starting this thread because I changed my CPU from a Duel Core Extreme X6800 to a Q9505. I have had the Maximus Extreme for some time, but besides for memory voltages, cpu multiplier, memory multiplier and vcore I had not done much. I had a modest gain, a 366mhz fsb -> 400mhz fsb at 1.45 vcore. This seems to be a limit of the chip since regardless of motherboards, I could never get it above this. I ended up finding out that I was sold an Engineering sample by a company that went out of business. This is a WATER COOLED SYSTEM.
This Post Will Be Modified OFTEN as more information and more responses come in.
NBV 1.25?
Multiplier 8.5
FSB - 333
Corsair Memory
Tools:
Multiplier - 8.5
Secondary- All Auto
SB 1.5v - 1.5v
Clock Speed 2.83
SB 1.5v - 1.5v
Point 1
NBVoltage 1.3
Point 2
IntelBurnTest v2.4
Point 3
Point 4
