I need some help to identify th4e board revision for my ASUS P2B-B M/B. When I turn it on the first info that flashes on the screen high right is a revision number "1.00.04-ET". Then that disappears and following info appears as it goes through the process of checking the memory and other devices. I will list them from top to bottom.
Bio v4.51PG
Asus P2B-B ACPI Bios Revision 1008.B
Bios Extension v1.0A
And finally at the bottom (where I was told the info I needed would be found) it says "3/22/99 - i440BX - P2B-B - 00"
Now I was told that the number right after the p2b-b would be the board rev. But the "00" is confusing me. My hope is that this board is rev. 1.02 so that I can put a PIII 800E CPU on it. That is the overall question I have. What is the fastest chip I can put on this M/B? Is there any other place to look for the revision number?
Thanks.
Bio v4.51PG
Thanks.
