Asus P2B-F Jumpers for 1000 mHz
JES
Alabama
Can anyone tell me the jumper settings for a P2B-F to use a P3 1000 mHz CPU with 100 mHz FSB?
Thanks!
cw823
Honeybadger Moderator
Earth
The only info I could find listed multipliers up to 8x. I'm sure someone around here who used or still has that board might be able to offer some help. As I see it it's unlikely that would work....but I've never had that board....so I cannot speak a definite answer.
Bender
Mysteriously Changing Senior
In Thelemac's Basement Eating the Chickens
The board should be fine with that chip. Try setting your FSB at 100 and don't worry about the multiplier. The multiplier is hardwired into the chip so the motherboard cant really change it anyway. The jumper settings will be marked on the board so you don't even need a manual.
Snarkey
Roanoke, Va.
Benders right. The chip will do what it does but the fsb can be kicked around at will. Great board. The manual is out there, but if you can't find it I can shoot it to you. Slocket and mb charts should give you what you need.
