Asus P3V4X best & safest way?
JR
I'm running a P3 600 and P3V4X how could I mod this board or bios settings to get the most out of it? I have only been able to run it @ 630mhz stable. please help. Thanks.
I also have this p3v4x (PIII500@667,PC133 sdram, corevoltage 2,3V(okay a bit high but it works)) and I think it depends much on the memory you use (as I used PC100 sdrams I got always 590mhz)
I have 600E @ 800MHz, also on a P3V4X. What is your setup? Are you increasing voltage? What do you have for cooling?
IM running the P3 600 on
-Win 98SE
-128k PC100 SDRAM Ive even tried with Kingston 256k PC133 but nothing different
-nvidia riva TNT2 Ultra
-CPU/ best cooler dual fan
-bios v106 beta 001
-Quantum Fireball Kx 27gig DMA66
I just got the P3 600@660 @2.0V stable but it was @ 91degC so I turned it down to 600 again and its still @ 84degC any ideas on better cooling
I understand that you are not using a coppermine?
Then I wouldn't expect you to go too high, somewhere between 600 and 700. Have you tried upping the core voltage?
Do you have good cooling?
