Hello again!
I have disabled the PCI cards and everything else. Here are my results from Wintune (3Dmark2000 break down after a short time running)
Your results have been saved in the file c:\WinTune Results.html.
Load this file with your browser to continue your system analysis and compare your results to WinTune's extensive database of similar systems.
Summary
Intel Pentium III
(1) 733 MHz
Windows 98 4.10.2222 A
Inno3D GeForce2 GTS/GeForce2 Pro
1024x768@16bits/pixel
2164 MIPS (Integer operations)
852 MFLOPS (Floating point operations)
187 (Integer application simulation)
182 (Floating point application simulation)
185 (MMX application simulation)
110 Video MPixels/s
389 OpenGL MPixels/s
478 Direct3D MPixels/s
320 Direct3D Null driver score
175 Direct3D Primary driver score
1551 RAM MB/s
133 cached disk MB/s
2,9 uncached disk MB/s
System Details
BIOS: Award 06/12/00
Bus: PCI,ISA
APM:
Possible 'hog' apps running: (none)
Other apps running: Current test status; ZAPalProxyWnd; WinTune; WinTune; DDHelpWndClass; Creative Mixer Starter; Energim tare; MS_WebcheckMonitor
CPU Details
CPU load: 0
low MIPS: 1460
CPUID: 0x0683 0x383F9FF
MMX Present: True
3DNow Present: False
Streaming SIMD Extensions Present: True
Processor Serial Number Present & Enabled: False
dhrystone time (s): 0,92
whetstone time (s): 0,012
Integer time (s): 4,2
Floating point time (s): 4
MMX time (s): 5,1
Video Details
AccOpt: Normal
Total video time (s): 5,7
Window open time (s): 0,017
Text scroll time (s): 0,016
Line drawing time (s): 0,57
Filled objects time (s): 0,13
Pattern blit time (s): 0,0071
Text draw time (s): 0,23
DIB blit time (s): 4,7
Window close time (s): 0,0086
OpenGL Details
Time (s): 0,22
Direct3D Details
DirectX Version 600
Time (s): 0,6
Null device test time (s): 4,7
Primary device test time (s): 2,9
Secondary device test time (s): 0
Memory Details
Memory Read Speed (MB/s): 1586
Memory Write Speed (MB/s): 1858
Memory Copy Speed (MB/s): 1209
Installed RAM (MB): 128
Free RAM (MB): 74
Memory used (%): 36
Page File Driver: 32-bit
Total Page File (MB): 150
Free Page File (MB): 99
Read speed, 4 KB blocks, MB/s: 2738
Read speed, 8 KB blocks, MB/s: 2762
Read speed, 16 KB blocks, MB/s: 2724
Read speed, 32 KB blocks, MB/s: 1717
Read speed, 64 KB blocks, MB/s: 1718
Read speed, 128 KB blocks, MB/s: 1718
Read speed, 256 KB blocks, MB/s: 986
Read speed, 512 KB blocks, MB/s: 498
Read speed, 1024 KB blocks, MB/s: 497
Read speed, 2048 KB blocks, MB/s: 496
Write speed, 4 KB blocks, MB/s: 3472
Write speed, 32 KB blocks, MB/s: 1850
Write speed, 256 KB blocks, MB/s: 1727
Write speed, 2048 KB blocks, MB/s: 383
Copy speed, 4 KB blocks, MB/s: 3014
Copy speed, 32 KB blocks, MB/s: 1380
Copy speed, 256 KB blocks, MB/s: 252
Copy speed, 2048 KB blocks, MB/s: 191
Disk Details
Disk Last Scanned: 00:00:00
Disk Last Optimized: 00:00:00
Cached Disk, 128 blocks
Open file time (s): 0,00027
Sequential write time (s): 0,0047
Sequential read time (s): 0,028
Random write time (s): 0,00044
Random read time (s): 0,0019
Close file time (s): 0,00037
Open file bytes: 1024
Sequential write bytes: 524288
Sequential read bytes: 4194304
Random write bytes: 65536
Random read bytes: 262144
Close file bytes: 1024
Open file MB/s: 3,6
Sequential write MB/s: 106
Sequential read MB/s: 140
Random write MB/s: 142
Random read MB/s: 129
Close file MB/s: 2,7
Uncached Disk, 2048 blocks
Open file time (s): 0,00028
Sequential write time (s): 1,1
Sequential read time (s): 0,65
Random write time (s): 1,7
Random read time (s): 2,7
Close file time (s): 0,0013
Sequential write bytes: 8388608
Sequential read bytes: 8388608
Random write bytes: 1048576
Random read bytes: 1048576
Open file MB/s: 3,5
Sequential write MB/s: 7,4
Sequential read MB/s: 12
Random write MB/s: 0,59
Random read MB/s: 0,37
Close file MB/s: 0,74
Anything wronng?
Best regards
Peter
