lifeguard1999 (Dec 18, 2000 09:40 a.m.):
I own an Asus P3V4X board, and I would recommend against getting it. My reasoning is simple. To get the most performance out of the board, you need to do a good amount of tweaking.
That being said, there are two types of P3V4X boards. One with the older ICS clock generator chip, and one with the newer Winbond chip. The ICS chip has 32 FSB speeds, but tends to overheat at higher speeds. Thus you might not get up to 150, 160, 166 MHz on the FSB. The Winbond has just 16 speeds and tops out at 150 FSB.
Again, I own an Asus P3V4X board with an ICS chip. It is stable. I like it. But if I had a choice, I would go with an Intel 815E board. Of course, when I built my system, the 815E was not available.
