- Thread Starter
- #201
I prefer the v26.6 prime. Bumped up the core to 5ghz and left the voltage at 1.325v. Changed the setting back to manual from adaptive and it's still good after 2 hours before I left for work. The prime version 28 was giving me crazy temps and according to everyone, it's for avx apps and here's something I read,
"Since AVX is aimed at improving parallelization, and most desktop applications are not suited for it, since contrary to popular belief parallelism is not the same as multi-threading, there are not that many applications outside specific use-case scenarios that employ AVX."
So that's why I've been using v26.6. TBH, a lot of people are using earlier versions without the avx and extra 20 degrees
- - - Updated - - -
Gotcha, thanks. Spoke with someone from silicon lottery and told them I'm at 4.9ghz with 1.325vcore and they said I'd have no problems hitting 5ghz after delidding. But if I can hit 5ghz without it, then even better.
and so far, I'm only at 1.325v at 5ghz so i guess I'll see how it goes once I get home from work.
And the vcore on hwinfo and asussuite shows 1.344v.
- - - Updated - - -
If you're testing it with a new/newer version of P95 then yes that likely the max voltage you will ever see from the system.
