Update: Using Prime95 now asNvidia says i have the latest driver and i dont see why they need to stress test my gpu as i havent even overclocked it. Anyways, started with 1.28v @ 4.8ghz, running prime95 latest version, blend test. Half an hour passed! Temps in high 70s, hitting 80C at the most. I dont know how I got 1.28v, i just figured id start at that, and so far so good. If it lasts a full hour, I will try 4.9ghz at the same voltage and i will try to hit 5ghz today and if i get a stable OC, i will stress test it overnight and for 24 hours straight. I will not go above 1.35v with prime95 as recommended by many, 1.40 if youre using realbench.
All I did was keep the XMP settings as well as the X4 settings for my M.2 drive, changed core ratio to 48 from auto, change voltage to manual and set it to 1.28. So basically just 2 settings, the core ratio and core voltage, thats it.
Took today off from work, so I got all day to finally get my new and first build overclocked
And I might sell my Asus Strix GTX1080 to a buddy's friend for $350 and get the new 1080ti since i got about 260 bucks in credit on amazon, id only need to put out about 100-200 bucks out of pocket to upgrade to the TI
. If not, ill stick with my gtx1080, like i said, it an handle 1440p at max settings so thats perfect for me.
So far, im pretty impressed with the CPU and I just started.
Regards,
-Jordan
Update: At 4.9ghz and 1.31v, it seems pretty good so far, but the temps on HWMonitor concerns me. It shows 90C at the max while Asus AIsuite only shows 78C. I figured with all the sensors on the motherboards nowadays, the AIsuite would be more accurate but i figured id ask anyway. Also CPUZ shows 1.25vcore so i know thats not accurate. I remember you saying the 7700k can go up to 90C, and i figured if it hit 90 at 1.32v already, then if i up it to try and hit 5ghz, the temps would be close to 100c or over according to HWMonitor but on Asus suite, it would be high 80s to 90C. Suggestions on which temp to trust? Obviously i saw this coming as prime runs 15-20 degrees celcius hotter, but i forgot about the different temp readings from differnt apps.
Got me thinking, maybe I should send it to silicon lottery for their delid service. 15-25 degrees is a big difference and would actually make the processor last longer IMO, since there will be less heat going through it and better IHS inside the CPU. Has anyone had experience with silicon lottery? Ive spoke to them and was going to do the same for my 6700k, and they had a point when they said since the CPU will be running cooler, it "should" make the CPU have a longer life but its more like having a cpu for 14 years compared to 15 years, or something like that. That's what they told me when i was going to send them my 6700k, but back then, i didnt want to start taking apart the custom PC that was built for me and void the warranty, but now i know how to put it back together, so im glad.
I also just ordered some Thermal Grizzly Kryonaut thermal paste for my 7700k build, as I have whatever thermal paste that the thermaltake 360 riing PWM AIO came with, so im gonna clean the old stuff off with some alcohol swabs and put a nice drop of the new thermal paste in between the cpu and cooler block, it should yield 2-3 degrees cooler, but im sure its better than what it came with.
Update: 4.9ghz at 1.31v ran for 1 hour and 15 minutes and then the last core(hyperthread/digitalcore) stopped working. Will try 1.32v, starting to worry that it wont hit 5ghz unless i use more than 1.35v which is not recomended according to the guide on ASUS's website unless I get the 7700k delidded.
