- Jan 12, 2015
This might have already been asked but could not find it in search.
I just bought some G-Skill TridentX DDR3-2400 (The Samsung Version) from Funsoul
Thanks Again
I put them in the Sabertooth R2.0 first. I have never had a problem running DDR3-2133 in the board. The BIOS showed the board topping out at DDR3-2133. When I installed the TridentX, the BIOS now showed DDR3-2400 as an option. I picked it at set the base 4 timings as shown on memory stick. Within 5 minutes I would get a BSOD that my Video, NTFS, Ect, Ect Driver has failed. I just took it as the Saberkitty was not made for that fast of memory. I swapped out the R2.0 for the CHVF-Z as it shows in the BIOS DDR3-2400 as an option. I had the same problems with the CHVF-Z as I did with the R2.0.
I have a memory fan running over the memory
I'm using a 2yr old Corsair H100i AIO. I'm wanting to say that this is the problem. With 2 Delta's on it (using the fan connectors on the CPU block) I had to drop my speed to 1600 just to be able to complete my BIOS setup. Once I got it up and in windows I increase the speed to 4000 instant BSOD. I finally got it in performance mode but that only kept it 30c
