I did a build Dec. '16. Everything seemed fined but after 10 weeks the PC all of a sudden shut off. I happened to be there when it happened. Removing everything but the CPU it would power on to Q-CODE 00 and red CPU Led. Replaced the CPU and processor and got things running again. It ended up being the processor that went dead.
Now 4 weeks later it happens again. I happened to be around to see it once more. Lucky me. This time Q Code 00 but no CPU Led. Fans will spin up on high.
I swapped power supplies and that doesn't seem to be an issue. In both cases I had it OC'ed to 4.2GHz at 1.25V. Temp are usually below 60 and don't go above 75.
HX1000i
Asus X99 Deluxe II
i7-6900k
I guess my question is? Am I missing something with this mobo? I have never had a build do this once let alone twice? Is the extra 4-pin ATX cable goofing things up? It seems to run without it but I figured I should have it connected.
Is Broadwell-e just super sensitive? I didn't buy an 8-core processor to let it idle. It runs some sort of load 24/7.
This second time I'm assuming CPU but I suppose it could be a dead mobo.
Thanks,
HX1000i
Asus X99 Deluxe II
i7-6900k
Thanks,
