- May 24, 2001
- Maine, USA
I oc'd the board via the fsb up to 149Mhz(1.39Ghz) with some errors. Tried going up to 150Mhz, checked Sandra and WPCUID and they said 1.35Ghz! So I maxed the Vcore voltage, tried again and it said the same thing, 1.35Ghz. Why is it doing this?? I have the VIO1 jumper removed to set the memory voltage to 2.5volts, since this is the Crucial spec. MY VIO is set to default(3.30v). Should I increase the voltage for the memory too? . My temp was around 44C. Please help. Thank you.
