- Oct 10, 2002
- Dallas, TX
after most of last night and all of today, I've finally got my new PC running, started off with USB Host conflicts and failed driver installations, moved swiftly on to no internet connection because the drivers that came with my USB ADSL modem don't work with XP and then ran into BSOD issues (probably caused by all those bad drivers!!!) I seem to have sorted it by re-installing XP.
Anyway, the spec is -
P4 2.4B C1 SL6EF (stock HSF at the moment)
512Mb Corsair XMS3500 CAS2
Abit IT7 Max2
Gainward GF4 Ti4200XP Golden Sample
Maxtor 80Gb D740X connected via "serrillel" adaptor
Enermax 431W PSU
Lian-Li PC65 Case with 4 Case fans
Windows XP Pro
Now, I've got it running nicely at stock speeds (apart from the 3:4 memory divider which I couldn't resist using!).
The problem is, whenever I try to change the RAM timings, I get BSOD, various boot issues and corrupt drivers!
This ram is only at DDR356, it's rated for CAS2 at DDR434 ???
The options that I've got are -
CAS Latency Time (1.5, 2 or 2.5)
Act to Precharge Delay (7, 6 or 5)
DRAM RAS# to CAS# Delay (2 or 3)
DRAM RAS# Precharge (2 or 3)
Enhance DRAM performance (Enabled or Disabled)
Bearing in mind the RAM that I'm using, I would expect to be able to run pretty much any timing I want at DDR356, but that's not the case, what would you guys suggest??
I've also tried upping the FSB more and leaving RAM at By SPD, got to 2.8, but wasn't overly stable!! (This was before my re-install, I've yet to overclock it properly since.
Thanks
Chez
Abit IT7 Max2
Enermax 431W PSU
Windows XP Pro
Thanks
Chez
