- May 27, 2002
- california
did u get the "SERILLEL" parallel to serial ATA converters and have u any problems with the supplied temp monitering program? also, has any one mounted an AX-7 on this board and it fits?
[XPerienceD] said:That Marvel controller is actually a converter of SATA to PATA! Actual SATA controllers won't be available until next year, from what I've heard that is.
Matrix78 said:so i'm probably wasting my time having the SATA drivers load up since all i have hooked to the SATA is a WD 40GB ATA100 ????
Sonny said:
Why would you use a Parallel ATA HDD on a Serial Controller via converter if you have normal IDE Controllers? Not the best choice I would think.
Matrix78 said:as was said by XPerienceD, just because i can![]()
Sonny said:
Slower performance just for looks, yeah that's really cool![]()
Sonny said:Benchmark it.
