Athlon 1,2 - Socket A - Asus A7v133 - CPU Fan/Sink Question
jasonr
Okay, relative newbie to the CPU installation thing.
I was wondering if this particular CPU fan/sink would work, and what you guys thought about the air flow and such before I buy it:
ThermoEngine
"Super-Charged"
http://www.coolerguys.com/CPUCOOL/Duron.htm is the page it's on, here is the info on it:
This includes the correct clip for the Duron and Thunderbird socket A.
6500 RPM Delta dual ball bearing fan
Fan moves 42 CFM of air
42.5dba
Includes Finger Grill (not shown)
Dimensions with Fan: 63mm x 63mm x 73mm
3 pin Molex connector to main board
Weight: 258 grams
Basically wondering if this will be a good fan before I buy it.
Thanks all,
Jason R.
DUDE...for the price...get a Global-Win CAK-38...All copper, and it comes with a Delta 38 CFM fan...
Does all copper make a big difference? If so I will get that one. ; )
Take care,
Jason R.
