- Aug 27, 2001
I have an Athlon 1133mhz at 53C idle, 58C load. The case temperature is 35C. My heatsink is a Globalwin FOP38 with a 60 to 80mm fan adapter and a cheap case fan on top. I did this because I couldn't stand the noise of the 6800rpm fan. I have one intake case fan (identical to the one of the cpu) at the front of the case. Between the heatsink and the cpu is the melted thermal pad that came with the heatsink.
I was just wondering if there was any possible way to lower my temperature without raising the noise level? Oh, and also without spending too much money
I was considering an Enermax variable speed fan (at a silent setting) to serve as an exhaust fan at the back of the case.
Any other ideas would be greatly appreciated.
Thanks.
Thanks.
