Do Athlons running with the 200 MHz run hotter that the newer 266MHz FSB CPUs?
I put an Athlon 1.2GHz chip (AXIA) with a Glaciator HSF on my Asus A7V motherboard. Motherboard Monitor shows 47C just browsing the net. Anything strenuous will push it to 50-51C. Room temperature is about 25C. I'm wondering if these chips naturally run hotter because they are configured at 100 x 12 in the BIOS instead of 133 x 9. Could this be why the temperatures in various reviews seem to be 7-8 C lower?
I've got a server at the office with the same motherboard, CPU and case. It runs pretty steadily at 41C. Do some chips just run hotter?
Asus A7V MB (Jumper mode, voltage default mode)
AMD Athlon 1.2GHz
Glaciator HSF ( Arctic Silver II )
Idle: 45C (Suspend mode will drop it to the mid 30's)
Load 51C
AMD Athlon 1.2GHz
Load 51C
