- Aug 19, 2001
- State of Confusion
I recently replaced a duron 650 I had running at 900 with a t-bird 800. I unlocked the L1`s with defogger paint, set the multiplier to 10 and voila...nothing...no post even
set the multiplier to 9.5.......nada..post but crash
set it to 9.....bingo.
I thought the 800 bird should hit 1g no sweat but it will only run the same mhz as my duron which acts exactly the same way at 9.5 and 10
My temps are good at 900 ( 35 idle 44 load)
voltage was set to 1.85 (reported as 1.9 by mobo)
my rig:
FIC AZ11-E mobo (meaning 100fsb)
256mb micron cas2 pc133
radeon LE
300w power supply (possibly be the problem?)
The mobo is supposed to be good to 1.2 t-bird with current bios. any suggestions?....thanks in advance!
my rig:
radeon LE
