Hey frostmeister,
I've got the same rig as you. A dual MP 2000 on an ASUS A7M266-D. Just for kicks I OC the system all the way to a
[email protected] before it crashed on me.
At stock speeds using a Geforce 4 Ti 4600 I got a score of 8925
After a few BIOS tweaks (
[email protected], Fast AGP writes, 512MB AGP Aperture *half my system ram, and turbo mode *I'm assuming that this increases the FSB to 134) I got a score of 9275.
Tweaking some more I found that the system remained stable at a FSB of 138...which resulted in a 3D score of 9525.
Keep in mind that these score are all with stock cooling (retail AMD HS+Fans, 2 chassis fans, PS fan).
I brought the system back to normal after I discovered my system's limits. I figured that with a dual MP 2000...you shouldn't really need to overclock at all. Perhaps when this becomes my backup I'll play around some more.
Ref.
Tests were conducted using 3DMark2001
If your going to overclock your system...I'd recommend these steps in this order:
1) BIOS adjustments (
[email protected] for all three settings, AGP fast writes, Turbo mode, and half your system memory set for the AGP aperture)
2) increase the FSB in the bios in +1mhz increments...make sure the system boots and check the temperature. keep pushing it till the system crashes. go back to the last good boot FSB and start to run torture tests.
3) of course, if you plan on keeping it OC, then make sure you've got adequate cooling.
good luck and tell me how it goes.
