- Jun 1, 2001
I have had an Athlon xp 1800mhz (2200+) for a while now in my current system. By most standards it is quite old, but I do not do anything cpu intensive, so it sits there idling most of the time. This is why I haven't bothered to upgrade.
When i first got the cpu brand new, it would only overclock to 1850 mhz without causing stability problems, even with .2V increase. So I figured I just got a crappy overclocker.
Lately I have been experiencing stability problems, I eventually had to UNDERclock the cpu down to 1600mhz to solve the stability problem. This is annoying to me.
Anyone have a theory as to why this might be? I even reinstalled linux, but it didn't change anything.
specs: crucial pc2100 ram running at 200mhz fsb 2.5-3-3 +.2v, nforce, NF7-M main board, geforce 6500 video, sparkle 450W power supply, thuroughbred 1800mhz 1.65v cpu running at 1.75V @1600mhz. global-win fop heatsink with the delta 38 screamingly loud fan. i also have excellent case cooling. 120mm front fan, 2 exhaust fans, and the power supply fan. etc etc.
Before someone asks, I can run memtest86+ all day and night at 200mhz fsb (400mhz) and expierence no issues running my 133mhz ram at 200mhz, which is got to be a ram o/c record!.
If i downclock my ram back to 133mhz, the cpu is still buggy at 1800mhz. so its definitly not a ram or mainboard issue.
I have swapped out the ram, video card, mainboard, power supply and even the heatsink and there is no change in cpu stability. i have also swapped out the cpu with a duron 1600mhz, and was able to successfully clock it to 2ghz (10x200). so i think my setup is more than capable. it's just that I have this buggy cpu.
I guess is i can't figure this out, i might buy a used cpu off someone. anyone got an old socket a kicking around they wouldn't mind parting with? i would consider anything equal or better then my current cpu in terms of performance.
